Televison & Video Logo
RETRO KICKS Posted on Jul 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emerson tv model ld190em1 no picture or sound has a red standby light and will not respond to remote or controls on the tv
Michael Harrier
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 125 Answers
  • Posted on Jul 22, 2017
Michael Harrier
Expert
Level 2:
Cheetah:
Answers
125
Questions
0
Helped
25208
Points
275
Bad power supply board..Mabe you could find the board at ShopJimmy.com
Usually around $35..
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
  • Posted on Dec 12, 2007
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Anonymous
  • Posted on Jan 18, 2009
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
kirtec auto
  • 1348 Answers
  • Posted on Jul 08, 2009
SOURCE: When i on the tv by remote the red standby light
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Anonymous
  • Posted on Jan 22, 2010
SOURCE: LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Anonymous
  • 1238 Answers
  • Posted on Nov 29, 2011
SOURCE: My flatscreen won't turn on it keeps going red to standby
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Power supply looks like this:
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
Try to watch this video about capacitors and how to replace it...
I hope this solution will be helpful...
Thanks for using fixya...
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
My friend took out the dvd player so the light stay on an when i tuurn it on it waits a sec then does red then green screen an goes to standby
The TV is indicating that a part of it is not working, like the dvd player that is missing. Modern electronics go through a set of tests and if a fault is found the stop working. Replace the dvd player, or get the set to a repair shop.
TV picture is smaller than screen, how do I make it bigger?
See if there is a "wide" button on the remote. Should scroll through the display size options
Go to menu and picture adjustments are there as well
Need tv code for emerson tv model#EWF2006 using RCA remote model#RCR312WR
These are the setup codes for Emerson TV with this remote control.
10017, 10154, 10451, 10236, 10463, 10180, 10178, 10171, 11394, 11963
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  5. If you want more details, check this.
I have a Emerson LD190EM1 Tv DVD combo. It will not work with my Dish Network remote. What is the IR code?
I also have the same tv with no luck on my dish network with the codes. However, I just did an autoscan and found the code, but it doesn't tell you what code. I am sorry I cannot give you the code, since manually entering them did not work, but the auto scan did work!
To run auto scan follow these steps.... it took me about 5 minutes to find on my dish network remote.
1. Press and hold the tv mode button until all other mode lights flash.
2. Press the red power button (not the red tv power button, but the power button which normally shuts off your receiver only)
3. Press the up button (about every other second) When your remote finds the code, your tv will automatically shut off.... once it shuts off, DO NOT press the up button again.
4. While the tv is off, press the pound (#) button.
Your remote will be programmed to your tv. Turn on your tv with the small red power button with the tv wording and test other functions (volume, etc.)
I tried this last night, waiting about 3 seconds in betwwen with no luck after 30 minutes, just a tired finger from constantly pressing the up button. But tonight I tried it on my LD190EM1 and paused for a second inbetween pressing up and almost fainted when the tv actually shut off within 5 minutes of starting! Best of Luck!!!
I have an Emerson TV w/dvd player model LD190em1 but do not have a remote with it. Can I purchase a remote from you?
Actually, this site is a technical advisory site, and they don't supply equipment, just advice.
You can go to Radio Shack or Walmart or Best Buy and get a Universal Remote, that can be programmed to your TV.
Follow the instructions to program the remote to your make and model TV.
Good luck, and hope this helps.
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
