Deleting your Google Account affects all data associated with that account and any services you use, like Gmail, Google Play, or YouTube.
You can delete your Google Account at any time, but you may not be able to restore it. You can also remove your account from a Pixel phone, Nexus device, or other Android devices without deleting your account.
Step 1: What happens when you delete your account
Once you delete your Google Account, you'll no longer be able to use the following:
Services you have to sign in to, like Gmail, Drive, and Calendar.
Data associated with your account, including emails, photos, and records of transactions.
Subscriptions and content you purchased on YouTube, like movies and TV shows.
Content you bought on Google Play, like apps, movies, games, or music.
Information you saved in Chrome.
Your Gmail username. After you delete your username, it can't be used again by you or anyone else.
If you use an Android device
If you use a Chromebook
Step 2: Update and download your info
When you delete your account, you won't have access to your data. Before deleting your account:
Review the info associated with your account on the Google Dashboard.
Update your info for services that use your Gmail address during sign in.
Update your password recovery info.
Learn how to download your data.
Step 3: Delete your Google Account
Sign in to "My Account". If you forgot your password, you can reset it.
Under "Account preferences," select Delete your account or services.
Choose a service to delete or select Delete Google Account and data.
Review what you're deleting and follow the instructions.
Choose Delete. If you accidentally deleted your account, learn how to restore your account.
If you can't follow these steps, your account might have been created by your organization or company. For help, contact your admin.
SOURCE: Cannot get the unlocked phone to work at all
This is quite easy to fix.
click menu
then settings
then call settings
then go down to network operators
then click on your network
easy as pie. let me know if it worked.
contact
[email protected]
SOURCE: I created a new account -want my old account back. Please delete NEW account thank you
Hi
When you deactivate your old account, do not go in to check at all as it takes 93 days for facebook to remove the account completely
Kind regards
SOURCE: Delete Google Play Account
Try going to Settings -> Accounts or something along those lines.
SOURCE: my boost mobile phone is locked and i forgot my google account info
You can try Pressing the emergency call at the bottom of the screen.
2. Input (star key)983(star keyl)987spawn key .the phone will go to the factory reset interface, and then press "Erase everything" (Don't check Erase SD ard). Finally, the phone will reboot by itself and there is no unlock and password any more after the phone is on.
Note:All your personal information would get deleted.
SOURCE: google account sign in
please sign in / sign up using computer first time and use mobile data internet packet (2G/3G) with desired SIM provider and download / surf for gmail .com / gmail login app in android then login to ur account using same password and user id that you logged on through computer and now you can create / set up new account
