Hi!
The manual provides a number of reasons why the ice maker doesn't work:
Ice is not dispensed
Did you stop the ice making function?
Is there any ice in the ice storage unit?
Is the water line connected and the shut-off valve
open?
Is the freezer temperature too warm?
(Set the temperature lower)
Did you wait for 12 hours after installation of the
water supply line before making ice?
I'm adding a link to the manual:
http://manualsbrain.com/en/manuals/948215/?page=29
SOURCE: Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
SOURCE: ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
SOURCE: Whirlpool Gold Ice Maker problem Model # GS6NBEXRS00
I hate to ask the obvious but is your water supply turned back on since the filter change?
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
