SOURCE: Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
SOURCE: xerox dc-12 system fault - Error code 10-389
that could be your fuser/youll maybe have to reset an nwm
SOURCE: xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
37,008.44:
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
SOURCE: we have a
Hi. The error message is telling you what the exact problem is. There is a problem with your touch screen control panel. Fixing this issue will need replacement of the defective part and needs technical expertise. Try this one first switch off the machine and unplug the power cord for the wall. Press and hold the power button for 30 secs. Plugged in the power cord then turn on the machine. If you still get the same error message then you need to call the maufacturers tech and have the part replaced. This will require taking-apart the machine to replaced the defective part.
All the best!
