SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
SOURCE: vulcan oven chatter
Sounds like your losing the voltage to the coil on the contactor.Are you handy with a multimeter?I can step you through it.
SOURCE: oven still wont heat up,after replacing thermostat,element checks
Check voltage at element while on. (dangerous) Make sure you have 240V across the two terminals of element. If not, then the control is the only thing left. Sound like the control has dropped one leg of power. Make sure you have 240 at the plug before removing rear panel.
SOURCE: Oven elements do not heat;
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1100 then it is the sensor that is bad & if the rating is around 1100 then it is the board that is bad & should be replaced. Hope this helps...
Daniel
