SOURCE: Remote doesn't work
According to Mintek support you should unplug your set for 30 minutes which is a reset/rebooting process. Then plug it in and hold the DVD eject button for 5 seconds [at least]. The DVD should eject unless there is another problem. If it doesn't eject then call Mintek support at 877-646-8358 for help. They told me you have to send the TV to them and they'll send a new one. If you have to do that then make sure you tell them you want your DVD returned when they get it out. Good luck.
SOURCE: Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
replace with new batteries and it works --- so simple
