Yes, you can connect the phone as a mass storage device via USB or bluetooth. Maybe there is even a PC suite software. Ask at http://chinamanuals.com - they a least have one for Windows systems.
Ok you should be able to go into JAVA on you i9 phone and select OPTIONS and delete the chinese games. As for other apps, I have not been so successful in finding the ones that are like the apple phone but here is a site that has games for your phone www.getjar.com
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
