SOURCE: rolled hem settings
Here is a link to purchase your instruction manual:
Pfaff Sewing Machine Instruction Manuals
SOURCE: please can you tell me if it is possible to do a
There is a definite art in doing a rolled hem at the best of times and on a delicate fabric you have to be good, there is no way of explaining you need to be shown.
SOURCE: what is the settings for
You haven't specified your overlocker make and model but some parts of the set up will be the same; you still need to consult your machine manual to find out the changes needed to the foot. Bernettes have a little switch near the blade that you flick to change how the stitch forms so it rolls.
You need a 3 thread overlock with the right hand needle (I'm assuming you have a 4 thread lock) turn the stitch length down to 0.5 so it is very closed up. And there is usually a little thread finger on the foot that needs to be changed or a switch you flick to move it back.
Then lower the tension down on the upper looper so this thread goes over the edge to the underside and tighten up the lower looper dial so this thread lies against the needle stitch.
Move the blade to the right so the fabric is cut wider than the seam that the threads are forming so the cut edge rolls underneath and is encased in the threads.
It is best to use wooly overlock thread on at least the top looper so this "fills" in the rolled edge.
If you visit you-tube and search using "Rolled Hem" or Nancy Zieman you should find some helpful videos too.
SOURCE: Can you please tell me
try this solution
http://www.fixya.com/support/t9307094-cannot_get_tension_right_also_trying
not exactly your serger model but technique will be very similar for rolled hem.
You need to set up a three thread overlock with the right hand needle, (take left needle out), and change the thread finger in the throat. Sometimes a switch to do this and sometimes it is a little piece on the foot that you change with a screwdriver.
Also, this solution http://www.fixya.com/support/t9280656-thread_janome_204d_serger is basic threading on 204D, it should be very similar to your model.
I have looked for a free download instruction manual for your machine without success. But you should be able to buy one from Janome or another of the online sewing sites like www.sewusa.com or www.sewingpartsonline.com.
]ve a manual you can somtimes find them on the Janome websit
Here is a link to threading up for 334D
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/New_Home_Threading_Diagrams/New_home_334_MyLock_Threading_Diagram.htm
SOURCE: I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
