Question about RCA Audio Players & Recorders
1963 RCA model # 4VF446 Studiomatic recorder changer # RP218 with floating cartridge. Where can I find a back up stylus and replacement bulbs for the control panel- AM FM Balance selector etc
6ya staff
SOURCE:
robotek
Graeme Ross
  • 1512 Answers
SOURCE: I have a 1963 RCA
Hi pab69874
Have you been able to test the speakers to determine that that is the problem? Parts are quite available for vintage gear, you just need to know where to look. If the speaker drivers are faulty, if you can give me the make and model number off the back of the magnet, I can source them for you.
regards
robotek
Posted on Jul 27, 2008
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: How do I get to the control panel on a Maytag washer?
First, does the machine stop filling if you pull the plug? If not, he is wrong and you need the fill valve. The piece the hoses go into. If it does stop when plug pulled then he is likely correct.
Pull machine away from the wall. Disconnect power. The control panel has two plastic end caps. The rear edge of each end cap will show a hole which has a partially covered Phillips head screw in it. Put a screwdriver in and remove the screw in each end cap.
Move to the front of the washer. Grasp each end cap and pull straight toward you about 1/4 " to 1/2 " then lift. The control panel should disengage from the top of the machine. The top of the control panel stays attached to the back plate of the washer. Rotate the front of the control up. This will expose all parts in the control panel.
Look for a 1/4" clear hose coming from inside the machine to one of the switches. This small hose can become detached from the switch and not send the "full" signal to shut the water off. It may also develop a small air leak which prevents the signal. If the hose is detached...reattaching and adding a hose clamp will prevent future detachment. if not detached, the pressure (level) switch itself is likely the problem.
Reverse the above process to reattach the control panel. If the machine is full spin to empty before testing your repair to remove water from tube. Good Luck.
Posted on Aug 23, 2009
Testimonial: "VERY fast reply...thank you so much for your help!"
Anonymous
  • 69 Answers
SOURCE: Stylus cartridge for a B&O record deck
contact this company for help?
service<remove>@turntableneedles.com
Note; take out the <remove> bit from the link to email them?
Posted on Oct 20, 2009
Martin Smith
  • 80 Answers
SOURCE: I have an RCA VHS Player/Recorder. Model VR557.
YOU COULD HAVE IT ON CHILD LOCK.IT SHOULD BE ON YOUR REMOTE SOMEWHERE.
Posted on Apr 24, 2010
Testimonial: "Thanks, very much. It seems that in my organization of manuals, that one got LOST!! Thanks again. "
Alan Hood
  • 195 Answers
SOURCE: Rowe Jukebox Model R-93
I suggest that you get a manual from www.victoryglass.com if you do not already have on, all the instructions for setting up the CCC will be in the manual.
Regards
Alan Hood
ami-man
Posted on Apr 29, 2010
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
I inherited a Garrard Synchro-lab 72B that I want to use to play 78 rpm records. I also bought a Shure M78S cartridge with the required 2.5-mil stylus. however when I started to work on replacing the...
Sometimes you have to invert a changer and place on padded supports to get access to cartridge. Be sure to identify wire connections to the old cartridge before removal and keep track of cartridge mounting hardware so it doesn't get lost.
May 12, 2017 | Audio Players & Recorders
My turntable keeps skiping for no reason, no matter the record. i also made sure the turntable was level. the turntable is a vestax 2000mkII
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
Nov 23, 2009 | Vestax PDX-2000MKII PRO Turntable
How do I replace a 1963 Wurlizer Jukebox needle?
Most stylus simply pull out forwards. The front end sits in a slight rubber groove and the back end is held in a metal clip. So you lift the front end and pull away in the direction the tone arm is pointing.
Oct 21, 2009 | Wurlitzer Jukebox 1015 One More Time...
WHAT IS THE STYLUS NEEDLE MODEL # FOR A RCA SS4000 RECORD PLAYER
Your source for all your antique radio, record player, turntable and phonograph needs!
Record Player Needles
Welcome to our record player needles and turntable stylus page! We hope you find this page to be very friendly and useful in locating a replacement record player needle or stylus for your phonograph. Use the picture charts of the record needles, and the information request form to help you identify which record player needle or stylus you need.
When it comes to stocking needles, we carry and stock more than just the "top brands", "most often needed" or "most popular" like other places you'll find on the web. Our inventory is very extensive and broad. Ranging from sophisticated high end types to plain straight steel needles for antique crank or wind up models.
Aug 31, 2009 | RCA Audio Players & Recorders
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
I have a 1963 RCA Victor Victrola record player/stereo that the speakers don't work. Where can I find replacement parts?
Hi pab69874
regards
robotek
Jul 26, 2008 | Audio Players & Recorders
181 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
