Question about Yamaha Boating
On 2009 Yamaha Waverunner will motor lock up if supercharger goes
    Sergeant:
  • 331 Answers
The supercharger is powered tru a clutch system. So, even if the clutch slips, the engine will be hard to turn around.
Posted on Nov 15, 2017
6ya staff
SOURCE:
Anonymous
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
Anonymous
  • 948 Answers
SOURCE: yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Posted on Jul 12, 2009
Anonymous
SOURCE: i have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Posted on Jun 28, 2010
durd wood
  • 5 Answers
SOURCE: 2007 vx yamaha waverunner cruiser...
check the fuel positionong sencer that nmight mot b opening all the way
Posted on Dec 25, 2010
jurjmarian
SOURCE: how do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
Posted on Jun 06, 2011
2009 Yamaha Waverunner won't spin and we have determined it's not electrical. Could it be the supercharger is locked up? And if so how do I CHECK to see if the s/c is locked up?
The supercharger is connected to the engine thru a clutch. I think it should slip in case the charger is stuck.
But maybe not enough to allow the electric starter to turn the engine.
Did you try to turn the engine by hand with removed spark plugs?
If the supercherger is stuck it should be possible to wiggle the kranckshaft a little ( play on the command gears and clutch of the charger)
Please give us the right Waverunner type...
Jul 17, 2017 | Yamaha Boating
Yamaha 1100 waverunner
they dont do a 4stroke 1100 high output ! 1800HO then 1800SHO !
Aug 08, 2014 | Boating
I have a 2009 Yamaha VX Cruiser waverunner there is a very strong gasoline odor when I lift the seat to check the oil or do other maintenance I'm wondering if this is normal, I bought it used it only has...
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
Oct 28, 2013 | Yamaha 2009 WaveRunner VX Cruiser
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
2009 Yamaha vx cruiser waverunner used to do 55mph now won't pass 35 mph
Nevermind those other answers, if its running on all 4the cylinders but just real sluggish and missing top speed then listen up, let's first rule out the possibility of a damaged impeller, now locate your airfilter box and remove the filter, just throw it away because last I checked dirt really doesn't settle on top of water, now locate your throttle body and remove the intake tube from it, now take out the 4 bolts that hold it on and find your flame arrestor element. I've dealt with this problem many times only to find out that the geniuses at Yamaha had installed this screen right after the butterfly which accumulates airfilter material and clogs
Jun 24, 2012 | 2003 Yamaha YZ 250
1989 yamaha waverunner. I purchased a 1989 25HP Yamaha Waverunner & was wondering how you check the engine oil?
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
Aug 12, 2011 | Yamaha Superbike 1098 R Motorcycles
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
Hi I have a 2009 Yamaha SHO i were just wondering why can you still hear some parts of the motor spinning after you have shut down the motor..
It is the supercharger slowing down from its high spinning cycle. Dont worry about it, because it is normal. Trust me, I asked the same question on my 2008 SHO. You have the same motor I do.
Dec 23, 2008 | Yamaha 12V Air Pump
Boating Logo
105 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
