Question about Yamaha Boating
Outboard yamaha 350hp 4strokes 2000 how much timing where is the timing point
    Sergeant:
  • 331 Answers
There is no setting possible.
The ecm monitors the combustion quality and adjusts the timing following the results.
It works with "ionic combustion sensors" - adapted for the first time on an outboard. They monitor combustion conditions by detecting the production of ions in the flame. The ECM adjusts the ignition timing based on the ion density to improve combustion.
Posted on Nov 15, 2017
2 Suggested Answers
6ya staff
SOURCE:
hichbiri
Huseyin Huseyin
  • 3469 Answers
SOURCE: Need the points gap and plug gap for a 1978 Yamaha 15C 15hp outboard motor
try this
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-18626-05-34_869.pdf
manuals are freely available on the yamaha website
Posted on May 28, 2015
Points gap on yamaha 3.5hp outboard engine
Safe rule of thumb is 2 loose leaf papers jammed between the points and one side of a cardboard cover for storing those pages between the magneto and the flywheel. Grew up poor and still use those trucks to this day.
Aug 02, 2018 | Yamaha Boating
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
Timing specs 30hp Yamaha outboard ?
Try this site..Didn`t know what year...Cheers
http://forums.iboats.com/Yamaha-Outboards/Timing
Jan 29, 2017 | Yamaha Boating
YZ426 IS RUNNING HOT CHANGED STATOR AND TIMING IS OFF
Hi, Anonymous and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
overheating YZ 426 YZ 400 426 450
02 YZ426F Header Pipe Glows Red 4Strokes com
Yamaha YZ426F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual Page 3
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 07, 2014 | 2002 Yamaha YZ 426 F
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
I need the torque specs for the big ends, crankcase and cyl. head of yamaha 90 outboard 1996
This will be a good source of info for Yamaha outboards: http://www.marineengine.com/boat-forum/forumdisplay.php?37-Yamaha-Outboard-Forum
Yamaha Outboard Forum
Jan 25, 2014 | Motorcycles
Exhaust pipe glows red hot at a steady low rev and at start up instantly hot also little sparks come of it when revving the throttle.
The timing is set wrong OR You cannot let these 4strokes sit and idle.They all do it.They need to be ridden to get the air flowing over them to keep things cool.30 secs. idle at start and after a ride,idle for 10 secs. then shut it down.The sparks will probably be carbon build up inside the motor.You get it hot and they break away and come out through the pipe.All the 4strokes are a HP motor and will get hot if you sit and let it run.Hope this helps
Feb 16, 2011 | 2004 Yamaha WR 450 F
Boating Logo
83 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
