SOURCE: Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
SOURCE: Farberware convection broil oven modle T-4850
Don't need to replace glass door, unless the glass is broken. Go to an auto part store and get the highest temperature glue you can get, glue the glass back into the hinge. After that, when you clean the door, take the door off and clean it in the sink, DON'T try to clean it ON the oven.
SOURCE: Farberware Turbo Oven -- Model 360 + Manual
The only thing you have to know is that pork and chicken cook at 325. Any baked goods with leavening in it cooks at 75 degrees less than what the recipes calls for but no lower than 275.
SOURCE: Need Part for Farberware Turbo Convection Oven Model 460
hello....i am getting ready to list an unused set of these trays on ebay......they are new in their box....if you need a picture i can send you one.......i'm looking for about 35.00 for the complete set of 3 in their box.....keith
SOURCE: I need a manual for
I have this manual. I have been using this oven for almost 30 years. (I love it!) However, I'm having trouble with internet connections at the moment. As soon as I can get a good connection again, I will scan the manual and upload it here for those of you who need it.
Hi linny91, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Please describe the problem you are having with the oven, and when you do so, please include the model number. That is usually on a label just inside the door or on the back of the oven.
