Here is the information you requested:
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
SOURCE: I am wanting the instructions for Mattel Junior Scrabble
This was painful!
Here is the website to download the instructions.
http://www.hasbro.com/customer-service/toy-game-instructions.cfm?page=&per_page=50&order_by=S¤t_page=2
It's about 1/4 down the page.
SOURCE: Mattel Junior Scrabble Instructions
where can i get instructions for junior scrabble ( mattel
SOURCE: lost instructions to uno attack game
About:
Uno Attack is a popular adaption of the original Uno game that involves a electric card shooter. The shooter has a launch button and when pressed 0-12 cards can be shot out.
Differences:
Uno Attack rules are very simular to the original Uno rules with several differences. Instead of a Wild Draw Four card, there is a card named “Wild Hit Fire”. When played, the next player must hit the launch button.
Instead of drawing a card when a player no longer has a card to play, they press the launcher button.
Players must yell “Uno” when they first place down their second to last card. If an opponent catches them not saying “Uno”, the player has to press the launch button.
Cards:
Besides the number cards there are several other cards that helps mix up the game.
“Reverse” – If going clockwise, switch to counterclockwise or vice versa.
“Skip” – When a player places this card, the next player has to skip their turn.
“Draw Two” – When a person places this card, the next player will have to pick up two cards.
” Wild” – This card represents all four colors, and can be placed on any card. The player has to state which color it will represent for the next player. It can be played regardless of whether another card is available.
“Wild Hit Fire” – When played, the next player must hit the launch button.
SOURCE: I've lost the instructions for
To get the manual go to the link below scroll down to the name of the game click on it. It is in ABC order. A new window will pop up and then click on the here under download instructions.
http://service.mattel.com/us/instruction_sheets_results.asp?Brand=5&Category=24&image1.x=11&image1.y=12
Testimonial: "Exactly what I Needed!! Thanks!"
