Vacuums Logo
Joy Dyer Posted on Jul 14, 2017
Eureka airspeed rewind pet upright vacuum brush roller will not turn
5 Related Answers
yeroc
Custom Exchange
  • 397 Answers
  • Posted on Jan 20, 2008
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Anonymous
  • 152 Answers
  • Posted on Mar 02, 2008
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Anonymous
  • Posted on Nov 17, 2008
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Anonymous
  • Posted on Mar 14, 2009
SOURCE: The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
1helpful
The vacuum handle won't recline. Everything else works great, how do I fix it?
It sounds as though either the pushbutton may be broke or out of alignment. The recline works by pushing the latch pawl out of the locked position to allow the handle to recline. I have the user manual link and while it does not have that particular maintenance item the beater bar disassembly should let you see the mechanism to see if it is broken.
http://www.eureka.com/FileLibrary/e3d6977195674480857fbdfd0948b1a6/en_88151_OwnersManual.pdf
Eureka multicyclonic
Hi, it's Jeremy from Crucial Vacuum.
Attached in the link below is the owners manual for your Eureka AS2030A. Provided is step-by-step instructions on how to assemble your vacuum.
http://www.manualowl.com/m/Eureka/AirSpeed-ONE-Pet-AS2030A/Manual/350835?page=1
You can purchase direct your Eureka replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Brush will not spin
First thing to check is the belt to make sure it is not slipping and make sure the brush roll isn't restricted.
1helpful
Vacuum over heats and shuts off
check to see if the brush is turning under it if belt is broke or slipping it will do that
Turned off can not restart
it has an auto shut off feature if the motor gets to hot try unplugging it wait 30 mins then try again
1helpful
"Eureka - Pet Expert HEPA Bagless Upright Vacuum - Mystic Purple" is BRAND new and burning! I literally had soot on my hand and up my nose and mouth after using it just now. I've only had it for 24 hours....
Sounds like the beater brush is frozen and the drive belt is burning up.
Check your directions on changing the drive belt for the beater brush. When you remove the beater brush, clean as best you can. At each end of the beater brush you will find a plastic clip. These clips hold the beater brush in the vacuum. Add some WD40 between the brush and the clips. Turn the clips by hand and be sure they turn freely. Reassemble and at the same time, put on a new drive belt.
If this solution is of help to you, please take the time to add a Thumbs Up to my profile for the assistance. Thank you. Paul
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
