SOURCE: Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
SOURCE: Kenmore Microwave Oven - Clock dosen't work
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in and try again.
If that doesn't work, you may have a problem with the keypad, but your best bet is to check your owner's manual first.
If for some reason you don;t have yours, you can probably get it via the Sears site.
Just enter your model number there.
A full Sears/Kenmore
model number has 3 digits, a dot, then 8 more digits, such as
On the resulting page, look to the right for the blue "View manuals"
button. Click there.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they will ask you to register.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.
If you still have toruble despite using the manual, you may have a failed keypad. If so, please reply back or feel free to contact me directly.
We're
William E. "Ed" Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: how to set clock on kenmore 721.62222300 microwave
Press the STOP/CLEAR button followed by the CLOCK button. Enter the numerical value of the time (example: 11:30 = 1, 1, 3, 0), followed by START.
These instructions are on Page 9 of your owner's manual. If you do not have a manual, you can download or print a copy for FREE at managemylife.com. For your convenience, here is a direct link to your manual:
http://www.managemylife.com/mmh/owner_manuals/11630/KENMORE-Countertop-Microwave-L0310005?brand_name_search=721.62222300
If you have questions, please post back and let me know. I hope this helps you.
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
SOURCE: i need the manual to set the clock on a microwave rhm 1712
Most of the time you just hit the clock button then punch in the time then hit clock again
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
