Computers & Internet Logo
S
Sara Roeder Posted on Jul 13, 2017
I have an old Toshiba Lap top. I had Next Step clean it and program it with the programs that I wanted. But now my enter key will not work after a year of working fine.
I have cleaned the keyboard last week when this happened, but I can't get it to work, please help, I have all my writing in it.
5 Related Answers
A
Anonymous
  • Posted on Apr 03, 2008
SOURCE: Toshiba Satellite Latop - Keyboard problem when entering password
my email add is [email protected]
i need to driver for my laptop model no.is
A60 satellite
can you suggest on my email add.
A
Anonymous
  • Posted on Sep 23, 2008
SOURCE: Kenmore Dishwasher Mdl # 665-16349301 QuietGuard2 Black
asdfaaf
Anonymous
  • 6 Answers
  • Posted on Dec 14, 2008
SOURCE: Dell lap top keyboard keys "s" and "a" are messed up
Ok, first try looking under the A,S & D keys and see if there is anything stuck in there by those keys.
You can then try blowing with mouth or a can of pressured air to clean it out.
If nothing stuck in there, does the keys feel sticky, if so, then there might have been some liquid spilled on it. Try to dry it out with a hairdryer set on medium to see if that helps.
keep me informed
Anonymous
  • 53 Answers
  • Posted on Feb 12, 2010
SOURCE: my computer hangs up
as it is an HP DV6000, with known motherboard issues, I would suggest try running a few other programs also and see if they hang as well.
herseytone
  • 84 Answers
  • Posted on Mar 18, 2010
SOURCE: my r and spacebar on my toshiba lap top wont
Replace Keyboard, click this link to buy: http://www.battery-adapter.com/product_info.php/products_id/3505
Testimonial: "yes but is it easy to fit one in let me know please "
5answers
Not compatable with windows 7
Hello
OK, please be more specific on the exact question or problem you are experiencing.
Kind regards
Andrea
5helpful
How do I change the name on a nortel phone?
To chane the name on the sets you'll need to enter telephone programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
1helpful
2answers
Change the inter callers name
ex. john = 5 -> 666 -> 44 -> 66
2helpful
2answers
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
1helpful
I would like to change the display names that are attached to each line. How do i do this?
The display should say Lines.
The display should ask for a line number
Press the list soft key
The display should say Line001 and the line name. if this is the line name you want to change... Press the show key (top right arrow)
The display should say Name
Press the show key (top right arrow) .
Enter in the new name for the line
Press the next key (bottom right arrow) . If you want to program additional line names press the heading key(top left arrow) till you see "Line 001; new name" and press the next key (bottom right arrow) repeat the procedure for the additional lines
press the Rls key when finished
3helpful
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
3helpful
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
9helpful
How do I change the extension of a phone. Currently it is 229 and I want to change it to 225
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
*On newer versions, The display should say hunt groups
The display should say Change DNs
*On older versions, the display should say Change DNs
Press the show key (top right arrow).
Enter in the old dn number i.e.229.
Press the show key(top right arrow)
enter the new dn number i.e. 225
Press the Rls key.
2helpful
2answers
We relocated a M7310 phone and it kept the extension of where it used to be. I need to change it to the extension it's at now and I've tried finding the Set Relocation option but I think our phones are too...
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming2.gif.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
The display should say Featr Settings
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Move sets from their old locations to their new locations
2helpful
2answers
NORSTAR M7310, EVERY TIME I PICK UP MY HANDET I HAVE TO PRESS THE VOLUME UP BUTTON. HOW DO I SET IT SO I DON'T HAVE TO DO THAT?
Press the next key 3 times(bottom right arrow) .
The display say Backgrnd music.
press the next key 2 times (bottom right arrow)..
The display should say receiver volume.
Press the show key.(top right arrow) change from use sys volume to use set volume.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
