SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
SOURCE: How much oil should my snapper rear engine 14 hp
The way i would do it. get 2 qts drain and flush oil out of engine. put the drain plug back in. remove the fill plug and fill with oil. i fill mine to the first thread under the fill and ckeck plug hole. keep the rest for adding if required.
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
SOURCE: My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
SOURCE: snapper riding mower carburetor floods engine it wont stay running
The carb. is working. Get a carb. kit and in it. They don't cost much.
