Question about Nerf Toys
Nerf crossbolt cocking mechanism is jammed forward and I can not pull it back. How do I fix this?
  • Lisa
    Lisa Jul 12, 2017
    I figured it out. If you open up the back flip up compartment, above where the magazine would be, to check for stuck darts, there are 2 orange things that fold inward. If I push them out of the way, you can slide the grey **** piece back. Just in case anyone else is having this issue. :)
  • cesar ramirez
    cesar ramirez Nov 25, 2018
    I did that but it won't stay
    Top Expert:
  • Nerf Master
  • 29,384 Answers
6ya staff
SOURCE:
Anonymous
  • 20 Answers
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Posted on Aug 17, 2009
Anonymous
SOURCE: nerf gun wont shoot
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Posted on Sep 17, 2009
Neander1
SOURCE: My kid opened the Nerf
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Posted on Dec 27, 2010
justin knapp
  • 11 Answers
SOURCE: stinger p9t is jammed
did it happen after you cleared a clip? there should be a release mechanism to clear the slide.
Posted on Aug 14, 2012
sharkman154
sharkman154
SOURCE: ok, so last week one
my cocking bolt broke too and now i cant find a replacement for it :-(
Posted on Oct 28, 2012
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Have a winchester 1906 pump .22lr, when the bolt is pumped back to cock the hammer, the hammer falls as the bolt is going back to battery. Now if I pull the hammer back to cock and then run the bolt the...
The cocking mechanism is not pushing the bolt back far enough to reach the purchase point of the hammer. I do not know if that model has any way to adjust the range of bolt travel, but it could likely be worn metal just barely falling short of the mark.
Can you find any noticable play in any parts between the cocking mechanism and the bolt?
Have you tried pushing the bolt itself back (inserting something in front of the bolt and push back) to see if you can make the hammer catch in that manner, to narrow the problem down to just the cocking mechanism?
You may need to have a reputable gunsmith look at it, which would also be much safer than trying to repair it yourself, as well as safer than trying to use it while in this unreliable state. If the hammer toches a round just a little too hard before locked in fully chambered position, you could blow out the extractor pin or even worse, as I'm sure you could imagine.
Oct 14, 2013 | Sport & Outdoor - Others
How do I unjam a double cocked nerf diatron
1. Make sure that there are two disks loaded in the launcher. They must be pressing against the pressure switch at the top of the chamber. 2. Use a screwdriver to push in the T-shaped switch that would normally be triggered when the priming lever is closed. When both switches are activated, the trigger should be unlocked, allowing you to fire and to release the priming lever.
Feb 15, 2013 | Toys
Stinger p9t is jammed
Aug 14, 2012 | Crosman Stinger P9T Airsoft Pistol Kit...
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Toys Logo
1,462 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
ANTISPAMMER
FastHarley
FastHarley
Are you a Nerf Toy Expert? Answer questions, earn points and help others
