NOTE:
The Fax Header must be set up to test the fax machine.
SOURCE: How do I get a confirmation page of a sent fax on Canon SuperG3?
Tx (confirmation) Report needs to be enabled before sending the fax. Super G3 is an industry standard, not a model number. What model of Canon facsimile do you have? I have most User Guides downloaded...so I should be able to provide directions on enabling Tx Report. Let me know.
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
SOURCE: I need to recall a fax that was sent 2 weeks ago
Have you tried looking at your reports?
You can print off your send and received reports to confirm if faxes have been sent or not!
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
