Question about Dell Office Equipment & Supplies
Dell C1760 Paper jam - some paper removed - but more wrapped around roller can be seen thro the out slot
6ya staff
SOURCE:
tech expert12
  • 521 Answers
SOURCE: paper wrapped around the red roller
lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Posted on Aug 08, 2008
Anonymous
SOURCE: clear paper jam in top feeder of HP 3055
IT HAPPENED TO ME, I HAD TO TAKE HP ONLINE HELP, BUT ACTUALLY U WILL HAVE TO OPEN THE WHOLE AFD LIKE LITERALLY UNSCREW IT OPEN CAREFULLY AND THE ROLLERS AND THEN U MIGHT MANAGE TO TAKE OUT THE JAMMED PAPER
Posted on May 13, 2009
Anonymous
  • 5 Answers
SOURCE: 1. My paper jam is
Always go for a panasonic printer ok that`s like a gud boy keep it up.....
Posted on May 16, 2009
kevin duggan
  • 96 Answers
SOURCE: paper jam at back roller
i don't think that is a back roller, is more than likely your fusing assembly. that would be the big roller just before the output assembly. unfortunately, once this occurs your fuser is not repairable. if you can remove the paper, this will happen again, with frequency. your best bet is to have the fusing assembly replaced. make sure you take it to someone that will guarantee the work for at least 90 days.
Posted on Oct 02, 2009
Wally Minor
  • 24 Answers
SOURCE: paper jam, unable to pull paper out
Yeah, I would be careful though and only take out what screws you have to and document where they came from.
Posted on Jan 08, 2010
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam.
also you should check that all of the picker fingers are all in place and clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/geoffrey_a52be3eb7822ef96
Feb 12, 2015 | Dell 1320c Laser Printer
Kyocera TASKalfa 3050ci Photocopier paper jam 0100
remove the fuser and look for paper between the induction and roller systems or wrapped around the fuser rollers
Aug 11, 2014 | Kyocera Office Equipment & Supplies
Dell c1760 printer paper jam but don't see any paper. Can't find a place to open to inspect rollers and such. Any suggestions will be appreciated.
Hi Randy,
I am responding to your question you asked four years ago. Today I had the same issue with my Dell c1760nw printer. It would say open the rear door to remove the paper, but i couldn't see any. Using a flat screwdriver, I snapped out the 1+ inch plastic pieces (three of them) and exposed a pair of screws. Then take off the rear door and remove two other screws next to the hinges-holes for the rear door. Now you can snap up the top piece that ll you need is to lift it to expose the fuser area. You should now be able to see possible left over piece(s) of paper. Carefully remove the pieces and avoid touching the fuser. That's all to it.Putting all back together should be easy using common sense. I found a single piece of paper just above the fuser in the enclosed area. I removed that and the printer was back to normal. i hope this helps you or someone else.
Jul 30, 2013 | Dell, Inc Dell Color Printer C1760nw -...
ADF jam
Most probably the rollers are sticky. Try cleaning the rollers with fibre cloth soaked & squeezed dry. Use a blower to clear any dust in between the rollers. Finally run the maintenance program provided. It should solve your problem. If its still under warranty, I strongly suggest you send it in for servicing
Jun 12, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Paper jam, unable to pull paper out
Jan 08, 2010 | Samsung CLP 315 Laser Printer
Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Jul 28, 2009 | Dell 1720dn Laser Printer
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
242 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
