I recommend you contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
SOURCE: Sony KT-T25SF8 Dead, no video or audio, low level clicking noise
Most likly the Horizontal output transistor has shorted out because of cold solder connections on the flyback transformer, and or a bad capacitor in the sweep power supply and or, a bad flyback transformer. If the set Did not blow the fuse, then mopst likly you will have a problem in the main power supply where several parts in a kit form has and should be replaced all together.
Turn the fader control .To the rear speakers.
SOURCE: I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
SOURCE: When the power is off to my Clarion nx501 the radio still is lit up
Did you have the ORANGE WHITE wire wired to some connection that is live all the time? http://www.manualslib.com/manual/573841/Clarion-Nx501.html?page=66#manual
