55 inch Samsung LED TV buzzing sound. Buzzing is independent of audio and will get better/worse when brightness is adjusted. Model UN55KU6600F. Mfg date June 2016.
you should just need to replace them they don't cost a lot to replace. if you can do it your self. or a friend do it for you. around 90% cheaper than a new board.you should just need to replace them they don't cost a lot to replace. if you can do it your self. or a friend do it for you. around 90% cheaper than a new board.
You can't post conmments that contain an email address.
Nov 8, 2015 - 25 posts - 12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
I had the same problem with the same model. The solution was to replace a capacitor, C622, which is located near a small blue rectangular plastic component. This component is a relay that is controlled by C622. I paid $2.39 for the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Thank you Russ. So, basically need to replace power supply then, right?
