SOURCE: Catastrophic Error when trying to register fingerprint
If you turn data execution prevention off (cntrl panel, system, performance steeings buton then the DEP tab) it will work.
It is better to add only the programs (.exe) from the BIN folder of your C:\Program Files\DigitalPersona\bin folders since DEP is a good security measure against many types of attacks.
The single fact that Microsoft keeps that bug around can be seen as "you will never get security with Big Brother". It is really ugly and, as an electronic engineer I think Microsoft Monopoily as somethiung to do with NSA CIA MOSSAD and wars.
I am sorry to say what my most honest intuition tells me :)
SOURCE: How do I change the fingerprint recognition for a updated user?
Click on your Start Menu, then select All Programs, then select ThinkVantage. Under this menu you should see the fingerprint reader software. Towards the lower left part of this screen you'll see a button to "Delete All Fingerprints"
SOURCE: My Vostro 220 Mini towere lock's up and restarts at random times!
Since Windows is giving the "recover" error, it is most likely a software issue. Open a "run" dialog box from the start menu and type in the following "eventvwr.msc /s" (without the quotes). This will open the event viewer. What you want to look for in here are errors in the logs that are created in the Application and System logs. Warnings are not important at this time, but the errors will help to locate the offending code. It could be a corrupted driver or a litany of other things. Let me know what you find. Feel free to explore the options in the event viewer as well as clicking on any links that are in the desription of the problems as these will take you to possible solutions from Microsoft.
SOURCE: Fingerprint Logon on Vsita gives "the computer name is invalid"
If you remember the admin password then you can login with a different credential (i.e. admin credential). Then you can open the finger print application and there is an option to see your old password.
