Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device...
SOURCE: REMOTE CONTROL
Check this link they have the perfect remote for your unit http://remotes.com/store/polaroid/flm2601.html
Hope that helps..........
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
SOURCE: Polaroid TDA-03211C Combination 32 inch, LCD-TV/DVD *1080i/720p*
Check required Codes for TV Here for DishNetwork remote.
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
