SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: My Life Fitness treadmill needs
if it is a classical model 9500/9500HR/9100/9100HR can take the card to a qualified technician mail, you must open the controller and change the following components: D4015L (2) 2N6507 (2) TIP110 (1) and in the latter case there to change the IRGBC40S.
if you treadmill is the Next Generation you should buy new and can find on sportsmith.com
