Question about LG Tablets & eReaders
Drop down menu from notification bar and home screen buttons wont work on long sides of lg 7.0 lte tablet, only on short sides. One side quit working 2 weeks ago, now other side doesnt work either.
6ya staff
SOURCE:
Anonymous
SOURCE: Tablet input button and the start button
doh
Posted on Aug 21, 2008
soufian mankou
  • 1234 Answers
SOURCE: after formatting my tablet, I need to reinstall
Hi there
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 28, 2010
Matt Gregersen
  • 22 Answers
SOURCE: I recently purchased an Archos
At this point you'll want to return or RMA the unit to Archos for repair/replacement. You can find information on how to do this on their homepage.
Posted on Feb 28, 2011
cougar123
John Sweeney
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
alicenyanumb
Alice Nyaga
  • 7 Answers
SOURCE: Have a Hkc P774A tablet. son put password on home screen. forgot password. how do I reset it. there are no volume buttons on the side?
Try to off it for sometime then on it again then go to settings then try to put a new password.
Posted on Dec 15, 2014
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Bypass security pattern on a Verizon 4G LTE pad?
Android systems can be full factory reset from the Android System Recovery menu.
For Recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose one by one:
- wipe data / factory reset
- Yes -- delete all user data
- reboot system now
Nov 07, 2014 | Pantech Element 4G LTE Android Tablet
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Aug 06, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Upside down screen on ipad
The Auto-rotation setting must be disabled. Enable it on the settings menu. Or if your tablet is running iOS 7, then enable auto-rotation on the Control Center. Simply swipe up from the bottom of the screen to launch control center. (It is like the opposite of pulling out Status Bar or Notifications Bar above.)
Apr 22, 2014 | Apple iPad 2 Wifi 16GB
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
Tablets & eReaders Logo
35 people viewed this question
Top LG Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
NOEL
NOEL
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
