Photography Logo
S
Susie Posted on Jun 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm going away tonight I cant remember my combination on samsonite TSA007 can I reset it help!!!
matt
Level 3:
  • Master 1,666 Answers
  • Posted on Jun 30, 2017
matt
Master
Level 3:
Answers
1666
Questions
Helped
696164
Points
9998
2helpful
2answers
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Tsa007 combination lock reset
Contact the manufacturer or replace the lock
15helpful
2answers
How to change lock code in TSA007 lock?
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
My luggage box is locked and l cant remember the pin mumber,pls help.
JUST.....THINK...THINK...THINK....until you remember the combination.....................................................................:))
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
1helpful
How to unlock 3 digit lock in samsonite suitecase
mcdevito75 here, You"ll have to find a store that carrys suitcases in your area for help or, you can try to contact Samsonite online at Samsonite.com
My combination padlock got stuck
Added: I understand you have tried some steps to clear the combination lock. Check this web page to make sure you have tried all the possible options:
http://traveltips.usatoday.com/reset-samsonite-3digit-builtin-combination-lock-61343.html
(Copy and paste the web address above into your browser to get to the right page.)
Hello, Drjayapanick -
I checked the Samsonite web pages to try to find information for you.
Go to this web page (Contact Us information for Samsonite):
https://shop.samsonite.com/contact-us
On that page you can use the form to send an email regarding repairing the combination lock on your luggage.
Or, you may be able to find a business in Mumbai which sells Samsonite luggage, where you can take your bag to find out where you can have the lock repaired.
50helpful
2answers
How do I set the lock on my Samsonite tsa007
Locate a very small hidden button. Press it with a small stick. Turn digits to new code, and open again.
Just locate that button first, close to the zipper.
Top Samsonite Photography Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
