What is the question? This sounds like a manual watch the L9 stands for the date of production. You can look this up on the internet. Google Bulova code dates. L9 is around 1970's if not mistaken. It is also rolled gold plate one of the lower end watches. Most manuals are 17 jewels, the more the jewels the higher the price and worth.
SOURCE: bulova 96R19 ladies diamond chronograph
Watch shops use a press to put backs on. Some will snap on using your thumbs, other need the press to apply more force.
SOURCE: I have a 1966 Bulova and I am trying to find the
mcdevito75 here, Best Bet, visit a small watch repair shop in your area, But I;ll tell you I have a little experience with older watches, fact is I just finished basic work on a frieds 30 Jewel 65 Bulova and couldN;t find anything online except at various Antique sites that I didn:t write down, your 30 jewel Bulova along with the one I fixed for a friend of mine is worth at least what it cost when brand new----over $100.00
SOURCE: I have a bulova ladies
You will need to contact Bulova or a local watchmaker.
Here is a link for Bulova:
http://www.bulova.com/contact/contact.aspx
Good luck.
SOURCE: I have an antique bulova
Hi!
You can't tell actually the date when it is manufactured by the serial number of the case metal.
However if you manage to open the backside and look in the inside there will be markings that will help in the dating of the watch.. Look at the image below for example
as soon as you open the back case there is a symbol (pointing by red arrow) that was being used that time for dating.
From the table below.
Dating at the early 50's are different. 2 digits printed on the backcase signifies the date manufactured.
L indicates 50's
M indicates 60's
N indicates 70's
so if you see a 2 digit stamped on the backcase for example is L2
then it means it is made on 1952.
You will not find this information unless there is a 2 digit on the backcase or you will find a geometric symbol inside the case of your watches.
I hope this helps
Please accept if you find this solution helpful
Thank you for using Fixya.
Alp
SOURCE: I NEED TO KNOW YEAR
A Bulova "M5" code would indicate that the watch was made in 1965. Vintage Bulova watches can be dated by this little alphanumeric code:
Lx = 195x
Mx = 196x
Nx = 197x
Px = 198x
Tx = 199x
Pre-1950 Bulova watches used a variety of symbols and numbers (e.g., 47 and 48 to designate 1947 and 1948) to show the model year of the watch. A chart of those symbols can be found here: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
