Confirm that lower washarm is rotating. Initially check by rotating by hand. Second mark arm position turn on unit stop and heck arm position.
Listen very carefully and confirm arm is turning. It is often found debris clogs the lower arm jet preventing the arm from turning.
Also check the water level in washer sump. Low will also keep the arm from rotating.
Hope this helps.
