Question about Dell Office Equipment & Supplies
Dell 3765 scanner sensor problem 062-360 - Dell Office Equipment & Supplies
Does anyone know how i can use my 3765 for a webcam i'm desperite i called vivitar and got the runaround. please help
You can't. The 3765 was designed as a camera, storing high-resolution images (and videos) to a memory card. It was not designed to stream live video to another device.
Jul 11, 2010 | Vivitar ViviCam 3765 Digital Camera
Scanner not working, but printer does print
Can you copy a document, when you put it under the glass? B&W and color?
If so, then it is a driver issue. Try reinstalling the printer by following the instructions located at...
962 All-In-One Inkjet Printer owners thread (W7)
If not, then...
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to pirchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Jun 01, 2010 | Dell 962 All-In-One InkJet Printer
Where can I download a users manual for RCA RP-3765 Clock Radio?
I tried this manual from a different model and it gives all the info needed
http://www.voxxsupport.com/images/manuals/RP5640/media/RP5640_DOC_OM.PDF
Dec 27, 2009 | RCA RP-3765 Clock Radio
AC adapter for ViviCam 3765.
The polarity is correct, but 400mA is not enough. One commercial supply I saw was rated at 2.5A. I even suspect 3v isn't enough as I have tried an external battery pack with D-Cells in it and after a few flash shots it wants new batteries. The camera itself seems to be over-sensitive to "low" voltage and complains about new or freshly charged batteries (see other posts).
There is a problem with these cameras in this battery voltage area. I have asked Vivitar what external voltage to use, but no reply. Good luck! I am sufficiently fed up with this camera that I may try 4.5v external supply and if it blows up, good riddance!
Mar 31, 2009 | Vivitar ViviCam 3765 Digital Camera
My RCA RP-3765 clock is not setting itself right
manual is good for thise model
Feb 18, 2009 | RCA RP-3765 Clock Radio
No software for vivicam 3765
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 24, 2007 | Vivitar ViviCam 3765 Digital Camera
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
