depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
