I have some different sources.
http://aeg-electrolux.manymanuals.com/ as a first option for user guides. You have to use search textbox or brand search. Enter your AEG Lavatherm protex plus and choose among other manuals.
SOURCE: AEG lavatherm condensor dryer error
Make sure the water is completely out of the catch pan.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
SOURCE: AEG Electrolux Lavatherm 57800:
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
SOURCE: AEG Lavatherm 57800 error E50
The problem is a worn motor carbon brush which connects power to the motor commutator. The carbon brushes are worn if the motor runs intermittently, if sparks are coming from the brushes, or if the motor doesn't run at all. This video should help you know more about motor carbon brushes and how they work. The video features a washing machine but the carbon brushes are basically the same.
SOURCE: euro-pro shark sewing maching model 7133 manual
Try this link to the parent site...at the bottom there is a link called manuals and warranties ...type in your model number you should get a PDF....
Peace in our time
