How do I install throttle catch on 61 husky
You have to remove the tank/ handle from the saw to do this, the tank is secured with 6 anti vibration rubbers 3 screws either side ( you have to remove the starter to see the screws on the l/h side ) unhook the fuel hose and throttle wire, the tank will then come away, the pin for the throttle lever is behind the top anti vibration rubbers ( the rubbers unscrew from the tank, you need a pin spanner to do this, the problem is nearly always with the throttle itself, their is a small hook/recess on the side of the trimmer that wears away. The part no. for the trigger is 501518002 the lock is no. 501518102
