Music Logo
A
Anonymous Posted on Jun 23, 2017
Where do I test for break in the Mx15r input cuircut if its not sending
Mx15r no sound from guitar but reverb coil makes noisewhen. Vibrated or shook so speaker works and amp works but no sound from guitar no noise when I plug it in
Mike Smith
Level 2:
Scholar:
New Friend:
  • Expert 65 Answers
  • Posted on Nov 21, 2017
Mike Smith
Expert
Level 2:
Scholar:
New Friend:
Answers
65
Questions
0
Helped
34484
Points
356
The MX15R has a clean and overdrive channel with a common input. The reverb is between these input channels and the power amplifier. The common link between the two, is the input jack and selector switch which chooses which pre-amp section to use. I would check out this switch and jack as most likely, one of the other is open.
5 Related Answers
Robert Graf
  • 269 Answers
  • Posted on Jan 24, 2009
SOURCE: Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Anonymous
  • 109 Answers
  • Posted on Jun 19, 2009
SOURCE: Crate 100 head. Reverb doesn't work.
Check the input RCA plug going into the reverb tank (silver box with two wires connected to it). Make sure the amp is off when you do this. Sounds like the output is working fine if hitting the amp does it.
Fred Yearian
  • 5603 Answers
  • Posted on Oct 14, 2009
SOURCE: amp powers up,all tubes lightup,can hear reverb
Bridge the preamp out to the power amp in with a short cable while suppling signal to the input..
IF that works, the switch on the power amp input jack is bad. You can try increasing the spring tension, but frankly these jack are poor quality
You could run it that way with a short cable or open the unit to do the repair.
Fred Yearian
  • 5603 Answers
  • Posted on Nov 12, 2009
SOURCE: How to remove amp from cabinet? reverb doesn't work.
SOMETIMES the handle screws must be removed as well.
I have taken a lot of these out and the key is to figure out which direction it comes out... MOST are out the back and sometimes a board across the back has to be taken off with four screws to clear a transformer.
FIGHTING getting the thing out when it catches on the Tolex covering is the USUAL problem. Takes patience and sometimes a blade to hold the Tolex back.
USUALLY the speaker baffle stays in place.
rokrgyrl
Teryn J. Bird
  • 6 Answers
  • Posted on Sep 14, 2012
SOURCE: How can I fix the buzzing noise on my Fender Frontman 212R if I've identified the cables and guitar itself as not being the problem?
... do you, by any chance, have non humbucking pick ups on your guitar? Just curious...
2answers
Is there a way to make the sound of the reverb on my deville 2-12 sound better ?
modding the reverb takes some electronics experience...if you know where the reverb circuit is. all you can really do is change the input caps that make the tone bright or dull... larger uf for dull... lower cap values for bright... it's in the signal circuits... dont mess with power caps. The schematic shows op amp into the tank and out of the tank to another op amp...Output of the tank to opamp.. Id double that input cap ( 330 pf ) to see if you get more response into the opamp... then look at the circuit C17-C18/R33-R34 894cf4a0-46f7-4f21-9667-be620f05b31d.png
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
How do plug your guitar into the boss rv3 which jacks
Plug your guitar into the input and a cord from one or both outputs to the inputs of whatever you are using. Meant to be run in stereo for best sound. Two guitar amps?
Reverb wont work !!!!!!! Hot rod deville 410
probably a bad reverb tank. there is a little inductor inside that shorts out easily/common. you cant repair it. its just easier to order a new tank. what you do to test is........turn on the amp with the reverb turned up all the way........ volume up on the amp at normal playing level.....then tap or knock on the reverb tank itself......if you get sound then the output of the tank is good/ no sound the ouput side is dead.......then what you do is unplug the ouput of the tank and plug the output wire to the input of the tank and tap/knock on it again....if you get sound then the input side of the tank is good/ no sound is dead. this is a way to test the tank independently from input to output. which side is bad is irrelevant, what is improtant is determining if the tank is toast. i can get accutronics tanks from my distributor at a better price than anywhere else. email me thru my contact page on my website with the tank code numbers and letters so i can get you a price also check my price with whats on ebay, etc. my website is yostamplifier.com
good luck
Hi my Marshal G15 is making an echoy twang when played loud (& open E chords). does this mean the reverb is broken?
I suspect the vibration when it is loud is vibrating a reverb tank within the unit.
Test this bylistening with headphones and see if you get same sound.
It may be the reverb has a resonance or the cabinet does that is sensitive to your E chords.
The shock mounting of the reverb may have failed to isolate the reverb tank from speaker vibrations... hence the headphone test.
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
1helpful
Jun 19, 2009 • Crate Music
Top AMP Music Experts
MrFixitSTTL
ADMIN Eric
ADMIN Eric
Are you an AMP Music Expert? Answer questions, earn points and help others
