Televison & Video Logo
A
Anonymous Posted on Jun 20, 2017
Sylvania model srcd804bty troubleshooting. BluetoothCD Micro System
Is the SYLVANIA SIP1527 any good?
I am a (Retired) Certified Electronics tech,With 35 years expierance, Behind my belt. End all a home audio (Fanatic) Sylvania, is nothing fantastic, End never was, It at the buttom of the (Audio) Chain,In qaulity.
1helpful
How do I replace on/off button on Sylvania Model 6427GFG
If the actual plastic button is damaged etc either the keyboard may be available or molded into the plastic cabinet----beneath the plastic buttons is micro switch or in the case of the on/off maybe a larger switch----you would have to go to Philips in any case so a remote may be a better option.
Sylvania dedsk/wall mountable i pod cd micro system manual
Hello
What is the exact model number to your device?
Keyboard on Sylvania wireless mobile internet device with Windows CE not working - does not recognize keystroke
Flip it over on the back and find a very small hole about 1in fron the right diagonal corner of the lower right side of the data plate. Insert a tooth pick in that small hole and depress the micro switch to load another copy of your CE system. If this does not do any thing then perhaps you will have to upgrade by flashing your machine.
See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
1helpful
My sylvania is dead how do I do a system restore to factory settings dell says F12
If this is the Sylvania SYNET07526, you turn it over on the back and find a small hole 1in diagonaly from the right lower corner. Insert a tooth pick in to the hole and depress the micro switch for about 10 seconds, mind you this is when you have the charger inserted fully into the machine.
Picture disappeared...have sound
Ur main video backlight board is dead.Must be replaced.
4helpful
3answers
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
Cleaning screen of Sylvania digital tv
a Mild cleaner...water and a micro fiber cloth.....if it smells dont use it!
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
