SOURCE: HD ready?
The TV is just HD ready (doesn't have the HD tuner built-in), you need a separate HD tuner connected to your TV.
SOURCE: Antenna for my HDTV
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
SOURCE: DTV connection
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
SOURCE: No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
