Leslie Vides Posted on Jun 17, 2017
How do I delete byway from my apple computer - Apple Audio Players & Recorders
1helpful
I used my apple id to set up my guys iMacs now my mail goes to his computer and mine.if i delete my mail account off his iMac, will it delete my mail too on my devices .
No. You can remove it from his Mac and sign in on another computer and the account will still be there. It's best to go to incognito mode when you sign your Gmail account into another computer. It will not keep your account in the computer. Be careful and never sign in to another computer when you travel unless you use the incognito mode. Google incognito and it will show you how to use it.
How to delete itunes wahen control won't let you delete?
Are you deleting it off of your computer or apple device?
Need to delete itunes and reinstall but control panel will not delete itunes how to delete?
According to Apple Use the Control Panel to uninstall iTunes in the following order and restart your computer :
iTunes,Apple Software Update,Apple Mobile Device Support,Bonjour,
Apple Application Support.
if your have faced any issue then follow https://discussions.apple.com/message/21392445 and
Apple and Mac Technical Support for more help.
Can't find control panel to delete down load
Apple menu> System Preferences and
Open your Applications folder and Drag the program or folder of programs that you wish to delete to the Trash. for more help follow http://www.wikihow.com/Uninstall-Programs-on-Mac-Computers and still need guidance follow Apple Tech Support .
My itunes just stopped working one day and now i can not reinstall it on my computer
Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this article.
Expand All Sections | Collapse All Sections
In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
  1. Quit iTunes.
  2. From the Start menu, choose Control Panel.
  3. In Control Panel, open Add or Remove Programs.
  4. Select iTunes from the list of currently installed programs, then click Remove.
  5. When asked if you would like to remove iTunes, select Yes.
  6. After the uninstallation is complete, do not restart your computer if you are prompted to.
  7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
  8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
  1. Quit QuickTime Player.
  4. Select QuickTime from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove QuickTime, click Yes.
  7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
  1. Quit Apple Software Update.
  4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove Apple Software Update, click Yes.
  7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, open Add or Remove Programs.
  3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
  5. After the uninstallation is complete, do not restart your computer if you are prompted to.
Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
Removing Bonjour
  2. In Control Panel click "Add or Remove Programs."
  3. Select Bonjour from the list of currently installed programs then click Uninstall.
  4. When asked if you would like to remove Bonjour click Yes.
  5. After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
  3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
  1. Restart your computer.
  2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
  3. Open the Program Files folder.
  4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
  5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  8. Open the Common Files folder.
  9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
  11. Open the Windows folder.
  12. Open the System32 folder.
  13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  15. Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. Press and hold Control-Alt-Delete. Select Start Task Manager.
  3. Click the Processes tab.
  4. Locate "iPodService.exe" in the list.
  5. Click "iPodService.exe" and choose End Process.
  6. Quit the Task Manager.
2answers
How to delete photos
You can only delete it from iTunes.
2answers
No power
try different mains cable to monitor.if no good.unplug.
nxt turn upside down and take back off monitor.any fuses? if so check they ok.
if no good take to local tv repair shop.type that deals in second hand tvs.
you can probably pick up a good CRT for £30 from a cptr fair or newspaper adds though: as people like TFT monitors.
byway.i dont.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
