Think it may be a line tension problem. every time I cast out, the line gets all tangled on the reel. brand new.
tried to fish with it for the first time yesterday.
shakespeare synergy low profile rod and reel
Try attaching the swivel to a chain link fence and walk away feeding the line completely out. Then begin reeling in the line at a normal pace with the drag set at max, after 10-15 turns decrease the drag a full turn. continue doing this until the line is fully retrieved. then set the drag as you normally would before fishing. Sometimes the line gets twisted while fishing which cause the tangles and backlashes. Make sure you use a barrel swivel also.
Wow, I can't believe that. That reel is very simple and shouldn't do that. I would guess that it's a problem with the line. Usually a real like that comes with line. Sometimes line is bad and it's very twisted due to being the last on the spool before it's put on your reel. I would suggest you buy some quality line, like Trilene or Stren and use about 6 lb test. I like the limp kind (read the box and it will tell you what type you are buying). Limp line means fewer twisting/tangling problems. Good luck. Alley
