Check out this image search for your specific motor..
MINN KOTA ENDURA 55 wiring diagram Google Search
SOURCE: I have a Minn Kota Endura 30, transom mount.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
SOURCE: minn kota endura 30 repair
The top section will pop off when the six screws are removed. It might just be dirty and sticking.
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
SOURCE: how do i extend my battery cable on my minn kota
You can purchase a battery extender cable. Depending on how far you need to go, you can buy them in various lengths. I've done the same and bought a 15' extension (always buy a few more feet than you think you need). Many places carry this. I bought mine at BassProShops for $25.00 and it comes with fuses which help to make sure you never fry your motor or battery!
SOURCE: Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
