Cameras Logo
o
oby1 Posted on Jun 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i find info on how to replace lens fuji HS 20 EXR front glass is damaged
Tony Parsons
Level 3:
  • Fuji Master 6,405 Answers
  • Posted on Jun 15, 2017
Tony Parsons
Fuji Master
Level 3:
Answers
6405
Questions
Helped
1650892
Points
20272
This is a specialist job requiring specialised equipment - your only hope is to take it to a repair centre and hope they still have spares for an outdated model. Be warned - it will be expensive. It may be better to get a replacement
My Fujifilm camera wont start up correctly.
This is 12 years old and if it has been left in a cupboard unused for some time, will require a good Fuji service centre to replace the leaking capacitors.
Fujifilm finepix HS50 EXR The screen come up with lens control error can I fix it myself
  • First, reset the camera to factory default settings. On most Fuji cameras like the X100T, XT1, and XT10, you'll press MENU > Go to setup 1 (the wrench with a "1" next to it) > and then click RESET > OK. Wait 30 seconds after the reset has finished.
  • Turn the camera off
  • Next, take the battery out of the camera and leave the battery out for a FULL 2 minutes
  • Take the lens off and then replace it 3 times
  • Turn the camera back on and cross your fingers!
If not successful rub the contacts gently with the erasure of a school-type pencil
Make certain you have gone through the Menu and done a full Reset at the lowest possible level.
Make certain you are using a incompatible SDHC card instead of an SD card.
Spray some WD40 Contact cleaner onto a Qtip and gently rub the contacts.
Most often that Error Code comes up after the lens has been extended against something, i.e. the camera was turned ON when something was in front of the lens, or it was still in camera case, or the lens was jarred.
If it is malfunctioning after a mechanical insult such as being turned ON when was still in a case it may need repair.
With many cameras with a lens that extends a vacuuming of the various lens barrels will dislodge lint or other foreign bodies that are causing a Lens Error.
How do i remove lens,to check & possibly replace lens cover.
By carefully dismantling the camera
Take a look at YouTube to see how to dismantle compact cameras and decide if you are happy to give it a go
Can anyone tell me how to remove lens from fujifilm hs 20
You can't remove the lens of your not so cheap bridge camera.
If you want to clean the lens, it really needs to stay on. After removing anything on or from this lens, you need at least a collimator, to align the lens elements. If not it won't be able to focus and could give lots or other errors in the pictures, like colour blur, aberration and out of focus parts.
How remove lens
The lens on the HS series cameras is fixed and is not meant to be removed. They are not SLR body cameras even thought they appear to be. You can buy non-Fuji filters and lens converters to fit on your camera but you can't replace the lens that is on it. It is a Bridge camera, meant to be between DSLR's and consumer point n shoot cameras.
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Fujifilm Finepix HS25 EXR screen replacement
Your best bet is going to be E-Bay, search your camera make and model under parts and you will find just what you are looking for.
4helpful
Where can I find a manual for my Fuji HS 20 on the net?
You can download the manual from the manufacturer's web site at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_hs20exr_manual_01.pdf
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
