SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
SOURCE: Need instruction manual for Logitech Harmony 525 remote control
Hi there, You can download the manual at the following location:
http://images.harmonyremote.com/EasyZapper/Downloads/UserManual/525/enu/525_UserManual.pdf
regards,
Craig.
SOURCE: I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
SOURCE: a Logitech Harmony 610 model universal remote control
Hi. I sure do know how to fix this! haha. Usually just taking the battery out for about a minute then putting it back in works, but if not it will get out of safe mode if you update the firmware.
1, Log in to the software.
2. Click 'Downloads' at the top
3. Click 'Firmware'
4. Update the remote
SOURCE: lOGITECH harmony 510 remote has locked up-
Hi! This is a really easy problem to fix. All you need to do is update the firmware of the remote!
1. Log in to the software.
2. Click 'Downloads' at the top of the screen
3. Click 'Firmware'
And it's fixed! Enjoy :)
Testimonial: "This was all i needed!!! Thanks so much- I will let ALL my friends know about you guys!!!"
