When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Change your memory card. I had same problem with my new Fuji Finepix S1000fd. Problem always came out in flash mode, with write/read error and freezing problems. Always use Premier brand memory cards. Prior to changing it, I also suggest to format your present card.
After surfing for solutions, I tried uninstalling all the Fuji software and using Windows to pull the pictures off the camera...It worked! Card and USB were working just fine even though they came back with errors using the Fuji software.
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories
The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB View all Fuji Digital Cameras
Sounds like a memory problem. You can try using the built-in menu utility function of formatting the memory (be it internal or external memory). Of course this will also delete all current files/photos in it.
Hope this be of some help/idea. Post back how things turn up or should you need further information.
Good luck and kind regards.
