SOURCE: Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
SOURCE: Loose wire in vacuum
http://www.filterqueen.com/contact-filterqueen-locate-distributor.html they will help you.
SOURCE: speed queen commercial dryer model
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
