Model KDL-60W610B using firmware 3004 AAA...
SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
SOURCE: Ford Fiesta IPod connection problem
You need the specific cable from Ford, part number 8M5J-19C142-AA, Finis: 1529487 which has a USB and an aux jack. It costs about £19. You need to plug in both aux and USB and then connect the other end to your ipod. You can then scroll through the playlists etc using the dashboard controls. When you have selected your choice, press the OK button and the ipod should play. You can use the steering wheel controls to move forward or back through the tracks and to change the volume. The instructions in the handbook are not very helpful.
SOURCE: D-Link DIR-625 Rev C FW308 - Cannot connect via VPN
- Logon to the config page of your router.
- Go to Advanced tab and select Firewall Settings at the left side
- Uncheck all the boxes under the Application Level Gateway and Save settings.
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
Hi Ted Killmeyer, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
how does it get the ip address automatically ?
