SOURCE: tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
SOURCE: WILL NOT POWER ON
isolate power from hor.output section. if voltage becomes normal 130v &it does not drop then power supply is ok. now check hor output for leaky compnents near eht specially capacitor & diode. check hor output tr. at last eht. you can clean print near eht.
SOURCE: power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
SOURCE: AKAI Stereo Integrated Amplifier Model AM-A1 - I
if the capacitors got plastic on their body there are the value
SOURCE: What is convergence output circuit or convergence
Convergence board output job are to hold those R,G,B CRTS Tubes colors guns in syn together to form a whole DLP tv pictures.These parts in questions on the convergence board are the 2 STK convergence ICS and some or all of it resistors.Any Big Screen tv shops,do the job for u.Parts and labors,should cost u like $300-350 max.
