Question about Boating
Evinrude 75 e8balcss - Boating
    Sergeant:
  • 331 Answers
Yes!
Posted on Nov 14, 2017
2 Suggested Answers
6ya staff
SOURCE:
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
How to set timing pointer 1977 75 hp evinrude
Have a look at boatinfo site it should help?
good luck.........
Sep 25, 2015 | Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
I'm looking for torque spec for flywheel nut and head bolts for 1988 evinrude xp 150 v6
follow this link for the head bolts , the fly wheel will be between 75-95 newto meters, click on torque tables
http://www.speedwayautoparts.com/index35.htm
Jul 15, 2014 | Cars & Trucks
Evinrude diagrams
This is quite normal,may have been blocked before
Mar 08, 2014 | Boating
1975 75 hp evinrude water in lower unit
You could take off the lower unit and leave the boat home. All they need is the bottom. The propshaft seal can be cut from fishing line. There should be another seal on the shift assembly and a third on the powershaft. Some you could do, but the shop can pressure test before and replace only what you need. Then pressure test after the repair to verify it seals.
Jul 20, 2009 | Boating
Boating Logo
118 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
