I need to find wave guard plastic rivets that hold the wave guard in place in a DAEWOO KOR6N35S Microwave Oven, 20 L i thought I posted this yesterday, but site now shows no record of it, despite email to me saying it was posted.
SOURCE: Plastic shield card is burning up!
It is my understanding that you can't get parts for a Welbilt Microwave anymore. The good news is that you can make one work from another m/w. Take your shield to a local appliance parts dealer and find a shield a little larger than yours. You should be able to cut it to fit your oven using the old one for a pattern. The rivets shouldn't be a problem as Whirlpool, GE, and Maytag all use similar plastic rivets to secure the shields.
Hope this helps.
Thanks, Mike
SOURCE: Arching when in use
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If the magnetron is damaged, it will have to be replaced, too.
If you or someone you know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
may also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If your brand and model are not shown, Please reply back with your brand and model number so we can help you.
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor,
the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed
discharge before testing, or you risk to get electrocuted, even if
power is off. Capacitors can get discharged by shorting their two
contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
SOURCE: micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
