First thing i would do is turn the circuit barker off to oven for one minuet and then turn it back on. feature not available is gone then press bake and start bake cycle. monitor the oven for 1 minute to ensure the error code does not display again. If it dose then you will need to get a repair service company to come check it out. they will have to enter the diagnostic mode and check for any other fault codes to make sure there is not something else causing the problem before the control board is replaced.
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
SOURCE: Error Code F8
For me...I disconnected the fuse. The F8 code would come on and off again with no consistency...after about 6 months I forgot about turning off the fuse....guess what it corrected it self and has been fine for 2 years now. I had got a quote on replacement of this panel...6000 to 700 $$$$$ I don't think so!
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Euro to USD conversion rate
