Try plugging the hole in the wall where the wire comes through. Also be sure you are not trying to reach your humidity set point therefore overshooting your cooling setpoint. Referred to "droop" in settings
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
SOURCE: dometic ac in RV
The relay board is exactly what the problem was, thanks "Guest" The 12vdc relays are normally closed and before I replaced the board I was getting a 6vdc to 7vdc reading on the (cool) leg at the thermostat with the breaker off.
SOURCE: I have a dometic duo therm roof ac unit that is
It is a closed system, (ends are soldered) that said, a heating and cooling guy may be able to install fill valves and re-charge for you, but make sure you get a quote ahead of time. How old is the unit? Not normal for them to need re-charge, and I've seen them work good for 15 years, if maintained properly. Has it been completely cleaned recently?
SOURCE: Dometic Duo-Therm Model 57915.622 Fan will not start.
Sounds like your fan motor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
