Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
1. Remove the updates for your Google Play
- Go to the menu->settings->apps->all->google play store-> uninstall updates, then reboot your device.
2. Remove the cache for your Google Play
- Go to the menu->settings->apps->all->google play store-> remove cache, then try to run your google play again. It is better to do a reboot.
3. Try to delete and re-install Google Play
- In some cases, delete and re-install resolve this issue.
4. Try to delete your google account and add your google account again
- Go to the menu -> settings -> account remove your current google account then add it again here.
When you uninstall updates to Google Play Store you are actually uninstalling updates to the Google Play Store app itself and not your other installed applications and their settings what you're actually doing is downgrading the Google Play app itself to the version that came shipped on your nook HD Plus. I know this Uninstall Updates wording tends to freak a lot of folks out because they think it means all updates to everything. In the app itself sometimes this is necessary if a bug is introduced into the most recent version of the Google Play app. Don't worry over time the Google Play app itself will automatically update itself again. If newer versions still have a bug on your system just uninstall updates again until they get it fixed. Over the last two and a half weeks a minor bug was discovered in Google Play that the very second you entered an apps description page Google Play would immediately stop responding to the system and crash. I sent a blind email to a Google support email address I hoped could forward it to the Google Play staff. I sent the email in about this problem about a week ago. It least on my Nook HD plus for the past two and a half days this problem seem to have corrected itself. Knock on wood.
You are the second question in a week about this very same problem between the Google Play Store app and Nooks. Hope this answers both questions and provides a solid workaround should Google Play Store ever get buggy again in the future.
